- Jul 14, 2003
Hello,
I need some help from oc-ers.
System Specs:
Asus A8N-E
OCZ EL PC3200 Platinum Rev 2 (2x512mb)
Fortron Blue 500Watts
MSI X800 XL
Thermalright XP-120 with 120mm (@ 7 volts)
_____________________________________
The problem is the crippled bios (1004 flashed, i see 1005, but couldn't d/l it). If I select DDR500 (250mhz), it will NOT let me change the timings on the ram, no matter what i change to it will revert back to 3-4-4-8. However, I can change it to other timings if its under DDR500.
Another problem is that the board does NOT offer enough memory frequency selection. The selection is like DDR200, DDR233...etc.
The memory frequency and the cpu freqency (HHT) is not independent of each other, if i change the memory frequency, the HHT will be changed too. If i change the HHT, the memory will change too.
I do not see any memory divider for which i can choose, but they do change with respect to the frequency (HHT and memory).
Do you guys have any suggestions?
thanks
System Specs:
Asus A8N-E
MSI X800 XL
thanks
