ABIT IP35 Pro or Asus P5K Deluxe w/E8500 - Likely going to use 4GB OCZ Reaper 8500
I like both boards and I've never tried an Asus board yet and would use the wireless it provides and am curious what the deal is with the possible DDR2 1400 stuff is all about using the memspeed bios features. On the other hand I'm wondering if I'd be able to run this ram on the IP35 Pro and get the same speeds out of it. I will be putting the Intel e8500 under my Vapochill LS and intend to clock the CPU into the 5.0 Ghz + range, is this the right memory to do it? I'm thinking it is since its does 533Mhz (1066 DDR) * 9.5 multi for 5.063.
I'm buying one of these two boards unless you can convince me that >400$ ram is the only way which I disagree already, so what ram and what motherboard within reason. I will be using it with (1) Palit G92 1GB 8800GTS. No Sli, 1 card is expensive enough and 9800GX2 is a tweener board and is the same reason I'm not so crazy about the motherboards that support both DDR2 and 3.
I intend to dual boot XP Pro and Vista Ult 32bit and game obviously...
ABIT OR ASUS - FYI: My last board was/is Abit IC7 Max 2 w/ 3.4 prescott at 4.51 operable 4.26 stable.
