- Mar 5, 2001
- Dillsburg, PA, USA
Ok, I guess maybe I should have started with spec's from the system ...
Begin Stat Run
Now originally in this system was an AMD Duron 800 MHz processor, so being a speed freak you can understand my desire for more ... that was where the AMD XP1700+ came in ... I had thought that I had read every possible piece of information there was out there on it to see if I could get it to work because it seemed as if there was a good success ratio with having this done on a Rev. 1.1 board. I am truely beginning to believe that I am one of the unlucky ones who has one of the 15% of the boards that will not accept the XP CPU. Here is what I have done thus far:
I cannot get the system through POST it seems because I get no beep, even trying the RESET trick that everyone else has tried. I am plum out of suggestions short of buying a new motherboard, which is I guess my last alternative. I was really trying to hold out on that so that I could save up and replace this motherboard with a good DDR motherboard, but I don't want to invest the money right now with all the money I already have tied up in my SDRAM for this board.
ANY OTHER SUGGESTIONS OUT THERE FOR ME TO TRY?
Begin Stat Run
- Windows XP Professional SP1
- Generic Beige Mid-Tower Case
- Antec TruPower 430W PSU
- Abit KT7A Rev. 1.1 / A9 Bios
- AMD Athlon XP1700+ AXDA w/ Cool Master HSF
- 1536 MB Crucial CL2 PC133 SDRAM (3 x 512 MB)
- 2 x 120 GB Western Digital 7200 RPM / 8 MB Spec. Ed. HD
- 1 x 45.1 GB Maxtor DiamondMax 7200 RPM HD
- 1 x 52x Creative CD-Blaster Drive
- 1 x 40x/12x/48x Lite-On CDR/CD-RW Drive
- 1 x 16x Delta DVD Drive
- PNY Verto Nvidia GeForce 4 MX440 64 MB AGP 4x Card
- Creative SoundBlaster Live! Gamer 5.1 PCI Sound Card
- Maxtor Ultra ATA/133 Adapter PCI Card
- DLink 10/100 Ethernet NIC PCI Card
- ADS Quad 4 - 4 Port USB PCI Card
- 2 x 80 mm Case Fans
- Standard CPU Swap w/ CMOS Clear
- After Swapping CPU's Tried The Reset Trick
- Removed All Excess Components Except Video Card, RAM, 1 HD
- Put All Components Back In And Removed All But 1 HD
- Put Duron 800 MHz Back In, Went Into BIOS And Set CPU Strength To 1
- Put Duron 800 MHz Back In, Went Into BIOS And Tried Manually Setting Up For This Processor
- Gave Up And Just Put Duron 800 MHz Back In Period
