Thanks Sam. I was refering to the 190 BCLK. I can do that my voltage goes from 1.31 at 165 BCLK to like 1.41 as well. I guess the CPU needs high voltages to hit that target while using Turbo boost.
How stable was your rig during those tests?
Depending on the processor model and several other variables, the processor will dynamically overclock one or more of its processing cores to boost its performance. The amount of overclocking performed is determined by an algorithm that takes into account these factors :
Processor Model - different processors have different limits on the amount of overclocking allowed
Number Of Active Cores - the amount of overclocking for each active core depends on the number of active cores.
Power Delivery Limit - the amount of power the processor can draw from the motherboard
Estimated Processor Current Draw
Estimated Processor Power Consumption
Processor Temperature
When the Intel Turbo Boost Technology is engaged, the processor will continuously monitor its current draw, power consumption and temperature. If they are all below Intel's pre-set limits, then the processor will automatically increase the clock speed of the active cores in steps (speed bins) of 133 MHz up till the upper limit allowed by the processor model.
Hooray, atleast now I know there's someone else was able to boot into Windows with Turbo @190bclk.
At 190bclk Turbo....I couldn't run IBT 5 loops HIGH nor CinebenchR10
.....But I've been thinking and wonder if better rams would make a difference.
Since turboboost kicks in at higher speed, Intel said nothing about if it does or does not overclock the rams during that higher boost.
Intel stated only that much below: (and wonder what their PRE-SET LIMITS are)
i have tried overclocking with turbo and all the other power saving features enabled with everything except dimm set to auto. but when i test using linx, computer either boots, freezes, or i get a BSOD. i really would like to use the turbo feature, but it seems this board is not allowing me to. when i just do a overclock of 3.8 with it off, tests pass. maybe i just got a bad batch of either the board, cpu, or both.
i tried what you said, but no luck. my particular board doesn't seem to like voltages set to auto and vdroop at low, at least when i put the cpu clock above 160.
it's good to be on-board. the weird thing that i notice is that with vdroop set to low, temps are higher. i updated bios to 1.6 because i heard older ones had problems with voltages. but it seems whenever i set them to auto, the computer restarts, BSOD, or freezes. i'll try with a lower CPU BCLK and get back to you. thanks for tips.
Yeah, I was just testing to see how far I could get with Turboboost.
I'm sold at 185bclk w/Turbo where it idles 1.360 and 1.376v loads. (@180bclk idle/load the same)
