- Apr 10, 2001
You guys have always given solid advice so I figure to ask what you guys would do in my situation.
I have a LGA 1156 system with a Gigabyte GA-P55-UD3R motherboard, i5-750 chip, and 2x2GB OCZ PC3 10666 memory. I had the system OC'd from it's base of 2.66Ghz to 3.4Ghz and it's been running pretty much trouble free for 3.5 years. I leave it on all the time, never powering it down except to reboot for patching. It has been connected to an APC UPS with surge protection to keep it stable.
I went to check e-mail yesterday morning and the monitor would not wake up from being asleep with mouse or keyboard input. I noticed the numlock didn't work so I checked the system and saw the HDD LED lit solid, so I knew it had locked up for some reason. We had storms the previous evening.
I tried the power button on the front, no dice. I had to turn off the PSU. When I tried to power the system back on...nothing. No lights, no fans, no nothing. Pulled the PSU and bench tested it with a MM and with pins 15 and 16 jumpered it fired right up and all voltages were all within spec. I removed all components from the board except memory and cpu, and still no dice. Not even a single LED. Then I removed the ram and cpu as a final step, still nothing.
So now I have a 4 year old system that appears to have a failed motherboard. It was plenty fast for everything I needed it to do so I have had no plans for an upgrade. I'm 4 years out of the loop on technology and don't even know what is good these days.
I've tried to find a similar board to replace mine with and am surprised at prices still over $100 for these. I did find some 1155s but my processor will not work on them. Based on what I'm seeing, the new stuff isn't that much faster than what I had anyway.
My drives were raid1 arrays in the system. So I'll have to get the data off of them unless I can find a board that they will just plug back in to.
So if you're in my shoes and don't game or anything, what do you do at this point? The most taxing thing I do on the system is occasional HD video editing and some PhotoShop work.
Thanks in advance.
Thanks in advance.
