- Nov 30, 2013
Decided to add a few more fans to my build,at the moment i havn't added any extra to the case.So i have the 120mm on the rear 1x 140mm on the front and the 120mm attached to the 212 evo.
Temps so far are at 31c which isnt too bad, but im thinking i should add another 140mm to the front,and debating whether its worth adding one or 2 x 140mm's or 120mm's to the top.
Any recommendations on what types,brands etc?
So far i think im planning on going with -
Top : Corsair SP120 Performance Edition 120mm Fan Twin Pack - 2x 120mm
Front : Corsair AF140 Quiet Edition High Airflow Fan - 140mm
Also gonna look into blocking up the windowed side panel fan holes,,dont plan on using them,and blocking them up will only stop dust etc getting in.
