- Sep 11, 2015
- Kanpur, Uttar Pradesh, India
Hey guys hope you're all doing well!
I recently bought myself a gtx 960 graphics card and to my shock and dismay it seems that it is being heavily bottlenecked by my CPU (AMD FX 4300). So I tried overclocking it but it just wont go past 4.0 GHz no matter what Vcore(or wahtever CPU-NB setting or voltage) I provide to it. (I have tried uptil 1.5v for 4.2 GHZ!) Nothing seems to work. I disabled all the power saving defaults for the mobo (an ASROCK 970 Pro2). And it seems that i am the only person with this mobo as well.
It seems there is a problem with mobo as well. Whenever i update my bios to any of the new versions. The system just wont start up properly(e.g. AERO would be disabled in windows 7 and the PC would perform like ****), i would have to then restart it to get it wrking properly and VOILA! everything would be back to normal.
Currently on BIOS version 1.3.
Other PC Specs-
4GB X 2 Corsair Vengeance 1600 MHz
Antec VP450 450 Watts PSU
Any help would be really appreciated as I really cant afford to change my mobo or my CPU(having just bought the expensive GPU)
Other PC Specs-
