Hi there,
I am planing to do a case mod and add water cooling to my system.
My main goal is to keep the system cool and as quite as possible. The decoration will come after .
My item list is as follows
My color scheme will be matte black and red, i will try to match the motherboard color scheme.
I have 2 questions for now.
Do i need to water-cool the VRM and is the pump enough if i decide to add another radiator.
Im not planing to go extreme overclocking because i want to have a quiet system.
Also i will use Asus Fan Xpert to control the fans.
Any other advice will be more than welcomed. Thanks
- EK-Supremacy - Acetal
- EK-FC R9-290X - Acetal
- EK-DCP 4.0 X-RES (incl. pump)
- EK-Tube ZMT Matte Black 16/10mm
- EK-CoolStream RAD XT (120)
- Black Ice GT Stealth 280
- NOCTUA NF-A14 PWM FAN x2
- I will add later the fittings when i decide on items and I have one NOCTUA NF-F12 (After i decide for items i will make a drawing with for the flow and how i will fit things in the case).
