- Oct 16, 2014
- Allagash, Maine
(or was that code for you pulled them out? lol)
That is what i ended up doing , removing the fans and tossing the Rad n CPU Block/PumpIf it popped out, best to just "Pop" in the garbage can.
There are some, indeed. However, the either have a fill port, or the in/outlets are supposed to come out.I have heard that some AIO'S can be refillable.
Those look like press fit. I was literally just looking at something last week that also had press fittings, and I can’t for the life of me find it again.Those fittings are supposed to be held in by some sort of U or C-Clip. If it popped out, best to just "Pop" in the garbage can. I'll bet the clip just dissolved itself since it's made of cheap plastic.
That might not be a good idea.Why not drill a hole in the radiator tank and epoxy a bung/plug in place?
Been done thousands of times successfully...same thing manufacturers do that offer the port.That might not be a good idea.
Oh, ok I just was not aware of that.Been done thousands of times successfully...same thing manufacturers do that offer the port.
