How so, what about Intel?
Alternate Data Streams
FRST lists ADS like so:
==================== Alternate Data Streams (whitelisted) ==========
AlternateDataStreams: C:\Windows\System32\legitfile:malware.exe [134]
AlternateDataStreams: C:\malware:malware.exe [134]
The size of the ADS (number of bytes contained) is shown in brackets at the end of the path.
If the ADS is on a legitimate file/folder the fix will be copy and paste the whole line from the log into the fixlist.
Example:
Code:AlternateDataStreams: C:\Windows\System32\legitfile:malware.exe [134]
If it is on a bad file/folder the fix will be:
Code:C:\malware
In the first case FRST only removes the ADS from the file/folder.
In the latter case the file/folder will be removed.
I'd suggest that you also check why all downloads have ADS, might it be from usage of HTTPS Everywhere or similar, perhaps from IE/Edge and SmartScreen?
c627627 said:Official version 10 is out and this BUG is still in there!!
After going through an entire release history of version 8 not acknowledging that this is a bug, and even after qmarius spelled it out, Comodo developers just officially released version 10 with this bug STILL in there.
Come-on guys, please fix this bug, there should have a been a version 8 release with this bug fixed. Now we're into official version 10 and it's still there, is this because the developers (incredibly) still do not view this as a bug or because there are other reasons Comodo is not allowing removal of existing alternate data streams... let's not speculate, what are those reasons?
mouse1 said:Very sorry but there is no fix yet, though the work-around is to remove them in Windows safe mode.
No new ADS will need to be created by CIS 10, as database tracking is used instead of ADS.
