What if FahCore_13 faIls to download? IE I delted the GPU2. I deleted _11 over and over again and all it wants to do is download FahCore_11
[00:03:34] Folding@Home GPU Core - Beta
[00:03:34] Version 1.13 (Mon Sep 29 12:58:49 PDT 2008)
From what I understand, you have to look in your logs for version 1.13 of FahCore_11. I believe the file name remains the same? Someone correct me if I'm wrong...
That is correct.
Ok... back to my two 8800GT cards giving me fits.
I think I may have found some evidence of the GPU2 core being CPU bound. When I setup these new clients last night I decided the get them running off the same CPU core. I was previously setting NV_FAH_CPU_AFFINITY=8 when I had these cards in my 780i/Q6600 setup. That setup both clients to run on core 3 on the quad, but when that setup busted and I moved the cards to my old trusty nF4 SLI/Opt165 (yes I still have AMDs ) I was still setting the affinity mask to 8, this made each FahCore_11 process run across both cores 0 & 1 of the Opty. No big deal, it ran fine like that.
So last night I switched the mask to NV_FAH_CPU_AFFINITY=2, which got both FahCore_11 processes running on core 1, and I simultaneously updated to core v1.13. That's when the problems started. Then I read where someone had said that their cpu usage had gone up with the new v1.13 core. Then it dawned on me that my old Opteron @ 2.9GHz might not be able to keep up with both FahCore_11 processes running on the same CPU core. Plus the fact that lowering my shader OCs on those cards wasn't getting me any better stability.
So far, so good... I setup each FahCore_11 process to run on its own CPU core, restored my previously stable shader OCs, and I haven't seen an EUE or UM yet. Just a word to the wise for anyone on a similar AMD cpu.
Ok well I guess fah mon just took longer than I expected. Its up to about 5400ppd.
I have had 3 EUE's in 8 hours, and haven't had a single one before this. Video card temperature 55C full load, CPU 42C so that's not it. Any success guys backing down the clocks?
[05:08:47] Folding@home Core Shutdown: EARLY_UNIT_END
[05:08:51] CoreStatus = 72 (114)
[05:08:51] Sending work to server
[05:08:51] Project: 5016 (Run 2, Clone 47, Gen 109)
[10:29:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:29:06] CoreStatus = 7A (122)
[10:29:06] Sending work to server
[10:29:06] Project: 5506 (Run 3, Clone 17, Gen 170)
[11:27:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:27:33] CoreStatus = 7A (122)
[11:27:33] Sending work to server
[11:27:33] Project: 5506 (Run 2, Clone 991, Gen 50)
same here.....I've seen more than a few EUEs, where before there were none.
We may well be making less ppd with the new core than the old one with all the EUEs. But hey, the numbers on FAHmon sure look good. Did you save a v1.09? I may have to recover one from the recycle bin.
