- Aug 21, 2005
Hey everybody!
I believe I have finaly decided to build a PC this month(Ive been looking, and researching of what to build, for the last year or so).
From what Ive heard from people on these forums, and on review sites, it seems like this might be a good build:
UPDATED July 10th 2006
CPU:
Meh, I think Ill get a Sempron Manila 3000, then once the price drops on the 3800X2 AM2 Ill get it(or something like that).
(hopefully I can overclock it too 2.6-2.8ghz)
Motherboard:
ASUS NON-SLI
(Asus does not seem to be compatible with some OCZ Ram...) Price $95 Mmm... Ive heard lots of good things about the Biostar TForce 6100, considering getting that. And it has a Onboard video, so if I do get a 7900GT I might as well get the Biostar board, just incase the GPU artifacts, and freezes up, I can still run the PC.
RAM
Corsair DDR2 800 2x1GB $158 AR
GPU
7900GT EVGA any recommendations on which version of it would be great! Thanks!
I am still considering a 7600GT because Im probably not going to be running games over 1280x1028(well 1440x900 which has about the same number of pixels), and it appears to me that the 7600GT can handle FEAR, HL2, and most other games at almost max setting when at 1280x1028 resolution or so. And it may save me $100+. But then again you guys seem to recommend the 7900GT, but I have heard lots of reports of trouble with the 7900GT cards.
PSU
I heard OCZ is great, and Sparkle too. Ive been looking at either a 600W Sparkle(or was it Forton) or a 520W-600W OCZ.
$120 or less. I dont want to spend more than I need to. Mmm... Rosewill 500W PSU is one of the few sub-$100(it cost about $60) that supports 24+Amps on the 12v(I need higher amps on the 12v fo the 7900GT right?), and it has a really high rating on Newegg from more than 90 people, and unlike some of antecs products, there have not been one report of it frying any componets.
Monitor:
Ive been looking at getting a 19" Wide DCLCD Screen, or maybe a 19" Wide Scepter(both I believe are made by Scepter). $200
And I already have a:
Harddrive 200Gb ATA Maxtor(but I am hoping to get 2 SATA drives in Raid 0 some time)
DVD Burner Nec 3550A
Case:
Was looking at a CoolerMaster. $50
Any recommendations, or comments would be great!
I am currently using a Dell 2.4ghz P4, 512mb Ram, and a Radeon 9800.
My budget is well... $1500 max, hopefully less.
I think Ill start buying parts for the PC this month(as I see the parts go onsale, Ill get em) and hopefully have a full PC by August.
And there is Conroe... but, doesn't that cost more? And wont K8L, and AMDs second Gen of Multi-Core CPUs come out next year on AM2?
CPU:
Motherboard:
ASUS NON-SLI
RAM
GPU
PSU
Monitor:
Case:
