- Jun 4, 2012
So I posted this here because I think my motherboard is causing me my issues. Let me explain:
Last night i built a gaming rig for a friend. Everything went well at first. The computer turned on, I went to the bios and then formated and installed windows on the hard drive. Then I unplugged the computer to change its position. I moved it to the other side of the desk and plugged it back in, but when I turned it on, "No signal" appeared on the monitor. I never had this issue before, where the computer would spontaneously fail after 10 minutes of use.
The GPU seems to start (fan spins and everything seems to be going well). Anyway, I used the old videocard (8600 GTS) and still "No signal". It worked in the previous PC. The gpu fan would spin erratically for the 8600 GTS. I didn't notice that issue with the new GPU (although that could be because its quiet.) I tested with different HDMI cables so I don't think that's the issue. Also, I tested the PSU with a power supply tester and all the voltages are dead on the spot (how they should be on a brand new corsair PSU)
I tested the monitor with an Xbox and it works well. I also reseated the CPU and RAM and everything seemed to be going well. The only thing that's left is the mobo failing.
I also tried to reset the mobo by unplugging the computer and taking the CMOS battery out.
The specs of the new rig are:
CPU: AMD FX 4100 Quad core Black Edition 3.6ghz
GPU: EVGA GeForce GTX550 Ti 2gb GDDR5
PSU: Corsair CX600 Builder Series 600W
MoBo: MSI 970A-G46
RAM: Corsair Vengeance 8gb DDR3
Please help me out with this. State the obvious if you think I might've missed it (yes I did plug in the hdmi cord on both ends). What do you think the issue is? Everything but the MoBo seems to check out. Could the MoBo cause a "No signal" issue?
MoBo: MSI 970A-G46
