2 things i have noticed after a lot of playing about.
1# had a good look at the card its self, the aluminum GPU heat sink has flat over runs at the bottom, they extend over the RAM chips supposedly to help cool them, the problem is the flat over run is just that, there is no step up so it can sit flush over the RAM chips.
Instead the inner corner of the RAM chips push against the cooler peeling it up so there is no actual contact on the top of the RAM chips, there is a silicon strip under the cooler but not even that is in contact with the chips, instead there is a 1mm gap between the chips and the cooler other than the inner edge of the chip which are digging into the cooler.
Whats more the lower side of the PCB is bent, the bend starts where the RAM chips are pushing against the cooler.
Its really shoddy workmanship, its would not take much work, or brains just to machine press a 1 or 2mm step at the inner end of the flat bit of cooler to accommodate the RAM chips and then fasten it on the outer edge so the cooler sits properly on the RAM.
Not impressed Gigabyte, not impressed at all.
2# Overclocking with voltage seems a problem for this card, unless i'm doing something wrong?
Afterburner 2.2.3, Catalyst 12.3 / 12.6 / 12.7. does not seem to mater...
I can set whatever volts i want upto 1.3 and it will take effect when idle.
I can see it in GPU-Z, however once i start benching, 3DMark11 / Heaven etc... the volts drop back down to 1.18v and the bench crashes.
I can get 1150Mhz / 1175Mhz at stock 1.2v, to get 1200Mhz or over i need to up the volts and no mater what volts i set, 1.23 to 1.29... it just sinks right back down to 1.2v and crash once the bench starts.
If i'm lucky 10% of the time it seems to hold, 90% of the time i can sit and watch the volts drop until it crashes....
