I used to be an amd fanboy back in the Athlon days, had an amd barton xp-m that I clocked to high heaven. I know back in those days the difference between the two was basically that the amd had a larger L1 cache and the intel had a larger L2 cache, this meant that the amd was snappier but when it came to raw computing power the intel won out.
Could someone sum up the differences these days?
I'm going to build my friend a new desktop and keep it as cheap as possible while upholding a certain level. I want at least quad core and 8g of ram. No overclocking will be done unless it's easy to do on stock equipment (not likely)
The cpu I have picked out for him is this
AMD FX-6100 Zambezi.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
I just picked a random atx motherboard and went with a brand that is supposed to be good (never owned one but heard good things)
MSI 970A-G43 AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130679
And for ram I think i'll give him my 8g of 1600 ram and get myself a small upgrade in the process for a few bucks. The ram is 2x4g of ddr3 cas11 and I can't remember the brand.
PSU is a corsair builder 500w, same psu I have on my machine and it works great
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
he already has a ssd that's only sata1 and only 60g but that'll have to do for now.
I haven't built an amd machine in 9 years and since that one I didn't do much research, just kind of threw them together so you could say i'm not up to date on either intel or amd.
Any thoughts or suggestions on this build? I don't want to go any higher on the budget.
MSI 970A-G43 AM3+
