jokersmoke
- Sep 1, 2013
i need help with my pc, it will freeze to where i will have to do a hard reset. i have a fx-4100 cpu on a m5a88v-evo board on stock settings. Even on stock settings my pc will freeze and even when i overclock it to 4ghz it will freeze even faster. This cpu should easily achieve a 4.2ghz clock speed just by raising the multiplier alone within the safezone voltages recommended for this cpu. Also when i stress test my cpu with occt i have gotten errors such as , error on core 03 and error on core 01. Also i get vdroop as well, but this is only when i am stress testing the cpu, it will fall from 3.6ghz(stock) to 3.3ghz. i do have cpu/nb load line calibration set to auto, i am not sure if this gives me the vdroop. Also while i am on factory settings, my board sets my cpu vcore at 1.4125, i am aware that this is pretty high for factory settings since i have seen other people overclock the fx-4100 to 4.6ghz with a 1.3008 voltage on other boards, and also is there anyone else with a am3+ board that has a factory vcore as high as mine. The awkward part is that i have no overheating issues, and yes i have a aftermarket cooler, a zalman 90mm copper ball bearing fan. My cpu on idle is 38 degrees on idle and when i stress test it goes to 52 degrees. Today i ran occt and 28 min. in my pc froze. My vcore was 1.29 and max temp was 48 degrees. Can somebody please help me out with this issue
Complete PC setup
AMD FX-4100
ASUS M5A88V-EVO
4GB Dual Channel Corsair Vengeance 1600 ddr3 ram (at factory settings my board sees it as 1333)
Seagate Barracuda 500gb Hard Drive
Sapphire Radeon HD 6850 1gb gddr5 graphics card
Corsair CX500 v2 PSU
Windows 7 Ultimate
LINK TO PHOTOS http://s802.photobucket.com/user/acekool2000/slideshow/
Complete PC setup
AMD FX-4100
ASUS M5A88V-EVO
Windows 7 Ultimate
