Hello all. I am new here and I searched and have not found anything describing the issues I am experiencing 'or maybe my kid is just making me go insane.' But I am having a issue with my *cheap* Fx build.
So I currently have a ASUS M5A97 LE Rev._2.0 Motherboard and a AMD Fx 4350 that I just recently built and I can't seem to understand whats with the voltage scaling so high even when configuring the bios not to compensate. (I'd better describe that one but not at the computer atm)
Also when running above stock speeds the temperature spikes insanely high even with only a 500mv increase above stock voltage of 1.3200.
So with my voltage at 1.3700 with asus's load line junk (sorry) it usually sits in windows under load at about 1.4250 which still is not that high (ran my phenom 2 x4 965 BE at 1.5 for a very long time till my H50 busted.) So is there some way to stop this from happening. I had to down clock to stock speeds and undervolt to 1.2 volts to keep the temperature below 76c where as to before id easily hit 90+ and the system would shut down due to thermal tripping. I've even tried with a older amd stock heatsink from my 965BE. Also with load line calibration off system become unstable at 3.7 Ghz with the voltage set at 1.4500 volts and will immediately BSOD upon booting windows but will boot a Linux distro fine.
PS: forgive me if this has been posted by someone else. I couldn't exactly find the information I was looking for other than asus messing with stock CPU-NB voltages. I have that locked at 1.2500V
