Attach the image to the forum so we don't have to copy, paste and waste our time. Thanks.
Thank you for your help.You'e memory is capable of running at 1600 mhz so why are you starving the CPU for data by running the ram at 1333 mhz? Also, we know nothing about most of your components. We need info about the motherboard, the make and model of the CPU cooler (or is it the stock cooler that came boxed with the processor) the PSU (make and wattage), video card make and model, and case (make and model, number and size of intake and exhaust fans).
And are you using AMDOverdrive to overclock this system? You really need to commit to learning to overclock using the manual bios tools. Use HWMonitor (non-pro version) to monitor various temps and voltages. Please download and install it if you have not.
Trust me, Dont waste yoour time and very likely money trying to Overclock and stress your nice CPU with that PSU. If you are lucky, you might get along with it for a while in stock setting, otherwise sooner a later you will encounter a problem and when it hits, it will hit big, very likely will take your MB and VideoCard as well some other System parts with it.
Good Luck.
You stated that were only using 1 stick?Corsair Vengance 4gb because my other stick failed
