- Dec 1, 2007
- Near Toronto Canada
USA prices for either the Intel or the AMD setup. You can compare what is available to you in your country where you can buy and decide what you may wish to purchase. Either 8-core combination should do well for your inteded use overall. I don't care what you buy and I do not suggest Intel in an AMD forum section unless the user is a gamer only. Where you wish to do considerable video editting, the AMD rig will serve you well for that and not be excessively off the pace in gaming. Good luck.
$339.99 Intel Core i7-4770K Haswell 3.5GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I74770K 4-core with Hyperthreading to appear as 8 core. Unlocked multiplier.
$239.99 Intel Core i5-4670K Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670K 4-core. Unlocked multiplier.
$189.99 ASRock Z87 Extreme4/TB4 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
OR
$194.99 ASUS Z87-PRO LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$34.99 Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
$159.99 AMD FX-8320 Vishera 3.5GHz (4.0GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8320FRHKBOX 4-module/8-core processor. Unlocked multiplier. Change multiplier to 20x for 4.0Ghz. Not a problem with either motherboard shown below.
4670K- $239+130= $369 for board and cpu
8350-
$184.49 ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
OR
$179.99 ASRock 990FX Extreme9 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
$34.99 Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan << You could add a second fan like the one that comes with the cooler for 'added' cooling when used with the FX 8 core processor.
IMO you're misrepresenting the cost of the Intel setup because you could easily run those chips on a $130 Z87-A and still get a decent OC.
239+130 (4670K)=369
184+159 (8320)=343
That's only 26 dollars more for the Intel system.
