Why 2600/2600 I thought 2400 was optimal and 2600 doesn't yeld any real gains?
As far as I've been told the only reason to push CPU/NB is if you have "high speed" ram.
Slightly OT, I just tried Aida64's stress test and temps stayed really low compared to Prime95. Package temps stayed below 45 C and socket temps maxed out at 55 C. Five minutes of Prime95 max heat test took me to 51 C and 68 C, respectively. Clearly Aida64 is pretty light when it comes to stress testing. If you want alternatives to Prime95, have you tried RealBench v2.41? Some people run the benchmark several times (10+) in a row to test stability, others just use the program's stress test, which is heavier than just running the benchmark. The "upside" is that it stresses the GPU as well, which may lead to hotter air inside the case and thus make a barely stable system unstable.
PS. My system produces a consistent result mismatch in the RealBench stress test even at stock settings, so I wouldn't pay much attention to that. If your system doesn't crash, your settings are likely okay.
I agree, P95 is a bit of overkill for your use. I use it just to get some peace of mind (if it's P95 stable for 8 hours, temps will not be a problem with anything I might throw at it), but if I were looking for the fastest settings possible for gaming, I'd use RealBench.
Btw, if you're planning on changing your RAM timings, calculating pi (SuperPi 1M or y-cruncher) is one way of testing stability. I was trying different timings some time ago to find the limits of my current modules, and while I could pass MaxxMEM2 and AMD Overdrive memory benchmarks with some settings, calculating pi with those same settings produced occasional errors.
Glad to hear it! despite what intel fanboys say these AMD chips well at lest mine anyways are sold chips for the price! I know for a fact mine oced beats the crap out of i5's in everything except gaming by what 10fps? does 75 vs 85 matter that much lol? hell I can beat out more I7's in lots of benches. Is it as poweful compared to the top end intel chips? NO but it's not far off and at 300-400 cheaper it's a no brainer.
Now gaming wise you have to pair it with an r285 or 380 at stock speeds but once you overclock the 8370e you can easily use an r390x without a bottleneck.
Sure the ipc is not as good as intel but to be honest this thing in 99% of tasks will crush i5's. Those sites that are intel funded will put amd into the ground everytime.
I do not hate intel nore do I hate amd, They both make good chips and I just happen to like the color red more then blue
"Many software developers think that the compiler is compatible with AMD processors, and in fact it is, but unbeknownst to the programmer it puts in a biased CPU dispatcher that chooses an inferior code path whenever it is running on a non-Intel processor," Fog writes, "If programmers knew this fact they would probably use another compiler. Who wants to sell a piece of software that doesn't work well on AMD processors?"
this was hashed out here quite a while ago (2 years?) In a large thread. I'm mobile or I'd link you. I recall hearing that there were still differences, but not as much? The problemishes isn't there, it's with the cpu. Hopefully zen tales care of it.Agreed, also take into account the fact that a lot of software use Intel compilers which are designed by default to give the lowest optimisation to anything but 'GenuineIntelProcessor' flag... I have a link to a place that goes in depth to discuss this and it was written up some 5 yrs ago... Source
If they were doing it back in 2010, how do we know they are not doing it today? Imo, unless your a professionally qualified programmer that knows their stuff and has access to the code, you wound never know.
This part is particularly worrying for Intel's competitors from that article link I posted..
