Evening all.
I own an amd fx 6300 with an msi 760gm p34 motherboard.
The motherboard has a feature to allow easy overclocking. If I run this utility in the bios I hit 3.8ghz.
If I disable the auto overclock and use the amd catalyst auto tune feature I can detect my processor and overclock 4.3ghz. If I run CPUz I can see the multiplier is 21.5 at 200 fsb with a voltage of 1.4 and a north ridge of 1.25
I then used these settings in the bios to manually set the values, saved them and rebooted the pc will not post. I have to clear the CMOS and try again.
Even setting the values at 3.8ghz I can't get the pc to post.
Any ideas?
Mike
Any ideas?
Mike
