IIRC, all X670 boards will be PCIe 5.0. B650E/B650, particularly the low end, is where you'll start to see a mix.Yes. Not all of the 1st PCIE slots will be Gen5 though. Costs savings by staying Gen4 spec.
PCIe 3.0 x16 only limits high-end 3000 series by like a couple of percent (at most, depends on res, etc). I'm imagining the same thing again in 3-4 years with PCIe 4.0 for the GPU.Which would not really bode well for next 3-4 years from now GPU's they will likely be pcie 5.0
Nope.Am I the only one that's starting to feel things have got a bit out of control.
I know man I know its like.. Pcie 3.0 is ok and 4.0 is now everywhere but it still feels odd when we are doing 4.0-5.0 and we are still friggin around with 3.0 and 4.0 on the main pcie.IIRC, all X670 boards will be PCIe 5.0. B650E/B650, particularly the low end, is where you'll start to see a mix.
Nope.
Any word on when they're dropping a 7xxxG CPU? My one main gripe with my HTPC right now is fan noise, so anything I can do to drop that is a plus.
I thought it could be interesting as it's quite a unique product:
Noctua presents NA-TPG1 thermal paste guard for AMD AM5
Designed in Austria, Noctua's premium cooling components are renowned for their superb quietness, exceptional performance and thoroughgoing quality.noctua.at
I just manually set all-core to 56 and set the voltage to 1.3, probably could use a tad more.Johan your oc you just disabled pbo and manual clocked it ?
With PBO mine is capping at 5.5ghz after touching the bclk 2 (1 in asrock case) or 5.490 if i dont touch bclk 2 both seem to hit a cap either way.
So far im not finding any gains with negative cpu boost override offset like some see only losses especially on the minimum boost rates .. but then again temps are all under 80 usually 75ish *C.
I got lost on the curve optimization a little i didnt see the changes expected on that either. (I have a feeling this is one of my main problems). This and finding the correct cpu offset mode in asrocks bios.
