Well I Used Orthos Beta To Stress Test. The Cpu Passes, But The Ram Craps Out After A Minute Or Two... I',m Back At Stock Speeds To Verify The Ram Is Going To Pass At Stock.
Error Output
Type: Large, in-place FFTs - stress some RAM Min: 128 Max: 1024 InPlace: Yes Mem: 8 Time: 15
CPU: 3003MHz FSB: 273MHz [273MHz x 11.0 est.]
3/1/2007 5:00 PM
Launching 2 threads...
2:Using CPU #1
1:Using CPU #0
2:Beginning a continuous self-test to check your computer.
1:Beginning a continuous self-test to check your computer.
2
ress Stop to end this test.
1
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:FATAL ERROR: Rounding was 0.48828125, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 1 minutes 34 seconds - 1 errors, 0 warnings.
2:Execution halted.
