- Jul 30, 2014
Hi all,
Got my T3 mini android box up and running works like a charm however I have come across a problem where its not possible for me to write to the SD card.
It was working before and I could write to it so I did an OS reset which didn't change things have tried reformat on both Android OS and within windows which has not changed things, previously it was formatted in Windows before it went into the box when it was working.
The SD card comes up in the storage folder but when I try to write to the SD card it won't let me do so. I have tried using various file manager apts to try get the device to write to the card but getting errors and it won't work.
The card works fine with no issues when I format it in Windows have put data onto it before putting it in the box to test it, also tried labelling the disk as this was suggested to try and get the SD working properly.
The box is rooted so I tried to change the permission settings in the android box but it won't let me update the platform.xml
Does anyone have a way to get this working again its driving me crazy have been trying various things on this since 11pm yesterday and was up till 5am and now trying again.
Cheers,
Bandit.
Cheers,
Bandit.
