- Sep 11, 2013
Sry if this is in wrong section
First off here are my specks
FX-8350
Asus HD7950 3GB
Asus M5A97 Evo
8GB Patriot G2 Series Ram
OCZ Mod Xtreme 700W PSU
so heres my problem
i purchased an antec 920 cpu cooler and it worked great before i upgraded to the fx8350
before i was using phenom ii x4 975 (O.C To 3.9Ghz) and the temps were great never went above 55c while running prime 95
so after i bough the FX 8350 i installed the cpu cooler and everything "seemed" ok, until i saw my temps
my temps are around 42 on idle and with like 2 min of prime 95 my temps skyrocket to 63c(not sure how much higher they will go,since i stop it at 63c)
ovcourse with normal gaming (skyrim with ENB Mod and HD Texture etc) my cpu temps are below 60 like 56c average
i know im still in the "safe zone" as long as i dont overclock
but im wondering why my temps are on the high side?
those temps would be acceptable if i was using the stock cpu fan, but im using a $100 cpu watercooler...
and yes iv tried re applying thermal paste and making sure its perfect...iv re-applied thermal paste several times..yet my temps are still the same.
my radiator is mounted in the rear of the case..both fans are sucking air from outside the case
im using "cooler master High Performance thermal compound"
so if anyone can give me some troubleshooting steps to help me solve this that would be greatly appreciated
i was really hoping on OC this thing
-is there a chance i received a faulty cpu?
-is there chance i received a faulty cpu cooler?
The cpu cooler's waterblock appears to have a few scratches..but doesnt seem "major"
Here is a screenshot of what happend just after 2 min of prime 95
Also notice how my liquid temps are Way off from cpu temps.
not sure if water just needed to heat up?
so any help would be much appreciated TY
----More info----
when i first used it on my phenom ii x4 i didnt use the cooler master thermal paste, i used the pre applied paste on the cpu block.
i used the "Dot method" to apply the thermal on the cpu.
Also i have this thing running at stock..and i also have cool and quiet disabled
FX-8350
Asus HD7950 3GB
Asus M5A97 Evo
so heres my problem
----More info----
