Holy Carp!! Anyway for the inside of your case you can buy small fans and some double sided tape to take care of hard to reach places that aren't getting proper airflow
I'm at work and they tend to block a lot, but his is an example of what I was talking about.
My 970 chipset board was like that too, the second i overclocked it went nuts so i changed to the 990fx.
I used to use one of these back in the day on stuff, maybe its still viable in this situation?
http://www.amazon.com/Antec-Spot-Cool-SpotCool-System/dp/B000I5KSNQ
Try replacing the stock fan with something more powerful?
I mean replace the fan that came with the cooler with something more powerful.im not using stock fan im using antec 920 cpu watercooler
Either a Delta or Nidec variable speed fan. They're a little expensive (about $30 per fan) but one is enough for just about any PC and you'll be able to reuse it later on.yeah i might try that
whats the best 120mm fans i can get...some that push out ALOT of air
my cpu socket is warmer than i wanted..but at least its not in danger zone
ill just have to keep an eye on my temps..until i save up more $$ to try real watercooling
ty to everyone who replied
Yeah they're extremely loud. Even when slowed down they are still louder than most can deal with.
