No not yet..im still at work...so just so i do it correctly...which one of the fans should be pushing /pulling?That would be 76 Fahrenheit. Which is ~24 Celsius.
That eliminates high ambient for a temperature issue, its most likely case airflow.
Did you swap the direction your radiator fans are facing?
Pushing--->[]<---Pulling correct?
So in otherwords both fans on radiator should be pushing air out of the case...ok..i had it like that before ..but i guess i can switch it back..ill do it once i get home....If you do that, you're going to net zero airflow.
It should go:
| CASE | <-FAN1 | RAD | <-FAN2 |
yes ..actually i had that turbo thing onThat helped your temps quite a bit.
About 3C on both core and socket.
Was that at stock speed?
Here are mine
Also this is what happens when i "attach" photos like i keep seeing with that pic tutorial... yea good luck reading it
I don't see how any of that would affect CPU temperature.
The socket temps are too high because of poor airflow in that area. Put a fan over that section of the motherboard and see if your socket temps drop. It should be ~10C higher than your core temp.
I mean that it should be directly over the CPU socket/VRM area.
