- Nov 16, 2002
- Neenah, WI
Onecare....low resource usage & tight integration w/ windoze FTW!
sobe said:Nod32, simple layout, best AntiVirus detection rates, and uses subsequently less resources than other available AntiVirus software.
KasperSky is good as well, right behind Nod32.
Hipcrostino said:Norton, McAfee and Symantec are all massive resource hogs.
I use AVG cause its free, but if i was going to pay, NOD32 all the way. (in the time i used it, ive never seen an antivirus thats so informative, but not intrusive with popups and crap)
Xtreme Barton said:question about one care ...
are their performance tools just a defrag and sys check ? well and them cheesy tcip optimizers too
Silversinksam said:
you told me absolutely nothing ..Velocity said:In Vista its more defined and runs really well to the point that you forget its there but doesn't catch all the crap thats in the wild. I would wait another year to see if it improves its self. But try it out and see if you like it.
