- Sep 7, 2013
Avira freeware will protect you better than most pay-for alternatives.
You should go with it *if you can set it up correctly. As posted in post#4 above, allow the configuration wizard to keep the default Express Setup options. [Do not Select All.]... and most importantly:
To disable Notifier nag screen: Windows 2000/XP Control Panel > [in Windows 7/8, click on (view by Category) System and Security first] > Administrative Tools [fourth from bottom] > Local Security Policy > Right click on Software Restriction Policies > Create New Policies SO THAT ADDITIONAL RULES SHOWS UP UNDERNEATH > Right click on Additional Rules > New Path Rule... > Browse... to the path of avnotify.exe default is
C:\Program Files (x86)\Avira\AntiVir Desktop\avnotify.exe
or
C:\Program Files\Avira\AntiVir Desktop\avnotify.exe
> Set the security level to Disallowed > OK
Also block these two files from accessing the internet, using Comodo Firewall or similar software:
C:\Program Files (x86)\Avira\AntiVir Desktop\apnstub.exe
C:\Program Files (x86)\Avira\AntiVir Desktop\ipmgui.exe
Excellent! I updated Kaspersky the day it expired So the defintions are still good. I'll wait a few weeks then switch to avaria
