Well, if temps are the problem, I have about 15c before I hit tjmaxYou not see 5.7 without sub zero cooling.
High end water you might see 5.3-5.4 but nowheres near stable.
Air, maybe 5.1-5.2, if you're lucky.
Damn. But you messed with bus speed though. I think I'll give that a try.
This is my record on water for my 8120 http://hwbot.org/submission/2326240_ssjwizard_cpu_frequency_fx_8120_5486.86_mhz
Are you still running the same vcore though? Or have you dialed it back since? My temps dont even reach those even during prime95. I think i saw it hit 46 max during full load. Would it be beneficial for me to mess with the bus speed and then go for a higher oc? Or should i just give it more multiplier and vcore?
8 cores at 1.7v on water is impressive BTW.
C/D you kicked it to the curb my man, along with a few other chips I have from you. I'm just giving them the treatment they needed to stay here....http://hwbot.org/submission/2680037
hey manny buddy, I've had relations with that board, just not the bill clinton type.
For the record Dpg these are obviously extreme clocks with extreme cooling. You should be willing to accept the outcome if all goes awry which occasionally happens, sadly.
Here's my top clock since we're all sharing.
http://hwbot.org/submission/2879359_blaylock_cpu_frequency_fx_4130_6645.82_mhz
EDIT: Also notice Mr. Scott is only using 2 of 8 cores for that. When pushing for top clocks there's no need to push all cores. Just one or 2 is fine.
That was not extreme. That was just high end ambient water. Only reason it's that high is because it was only on 2 cores. On 8 cores, maybe 5.2 ish.
On the chiller it's a totally different ballgame.
Chilled water i can bench at 5.7 easily
Thank you. I couldn't get the core stable at 5.1. I think cores 5 and 6 kept failing prime95. Do you think I should stop there? I wasnt really planning on trying any futher since i didnt want to pass 1.55 and it couldnt get stable at 5.1 with that vcore. so i gave up.I would absolutely run that. Well done.
