- Jan 12, 2001
- Kansas, USA
I'm adding a second rad to my loop in the front bottom of the case. I can mount it in the normal way with the barbs at the top, but it would be way easier to fit and run the hoses if the rad was rotated 90 degrees (mounted sideways). I'm sure it work, but will it be a nightmare to purge air? My res is at top front, pump in the middle front, then the single new rad would be lower front. I figure let gravity do it's thing by using the top rad barb as the inlet and bottom barb as outlet. Next in the loop is the waterblock, then double rad in back, finally back to the reservoir.
