I concur.phaeton said:With the intake mod it (MPC350) rivals the 655.
I figured you mistyped.
citronym said:Danner Mags are close in reliability and performance to the eheims, and you can buy them locally at places like petsmart.
Didn't you have the thermal shut-down threshold set?
The MCP350 might look small but it has a lot of bark. However, I completely understand not wanting to spend that much on a pump.soloz2 said:I don't think I want to spend that much on such a small pump
soloz2 said:so for a multi block system w/ 1/2" ID tubing would the d5 or mcp350 be better? and how can that little pump have such a high head, but low flow?
also, how would the dd mag pump be? it's about $25 cheaper
soloz2 said:I put some foam underneath it and I wrapped it up in a small towl. it's much quieter now. I don't think this is a permanant solution though... I may need to look for another pump. any suggestions for pumps that won't break the bank?
Ankun said:sounds like a good permantent solution to me. All good pumps have isolating foam to reduce vibration. If you take any pump and put a non-foam part directly onto your metal case it is going to vibrate madly and be extremely annoying. My D5 just has a foam pad on the bottom that the screws go through to mount it to the case. Problem solved.
soloz2 said:is there more than one version? I think I saw something about 2 versions of the swiftech mcp655?
soloz2 said:ok, I just wanted to make sure. I still have to decide what pump to get, but that is a contender. I think it'll come down to price. I've read a few reviews and it looks to be the best pump... but it is also one of the most expensive pumps too...
I've been shopping around and the cheapest I can find it is 83.15 shipped from voyermods... never ordered from them. anyone know of a cheaper place?
-aDaM^ said:$79.95 and in stock
http://www.sidewindercomputers.com/swmc12vdcpu.html
soloz2 said:I saw that. it would be 84.83 shipped. is that a good place to order from? how is their support?
dabombnl said:I have the Hydor L30 and it is almost silent (maybe 10 dB). I think you did something wrong if its that loud.
Check your flow, if water is not moving then the air will never get out of the pump.
Give it some time, depending on your flow rate, it can take as long as an hour (or a day) to bleed out the air.
Did you run the pump dry? It could have been damaged.
I would also keep the suction cups on to minimize vibrations.
