How can you tell it was throttleing? I didn’t see any voltage, multi or frequency drop? Things seemed pretty consistent, and stronger than stock. What app can I use to see this happening? I had AIDA64 and coretemp open for monitoring temps and voltage. Nothing on the power side of things is on auto pilot, I have the machine set myself. Where did you read that the CPU would do that on its own? I’d like to read that too..
Everything you could possibly want to learn regarding Intel processor design specifications of all the generations is accessible in the below link, your 3770K is 3rd generation.
https://www.intel.la/content/www/xl/es/processors/core/core-technical-resources.html
Ah what the hell, I was going to make you wade through it, but this may actually help onlookers in their understanding as well.
https://www.google.com/url?sa=t&rct...et-guide.pdf&usg=AOvVaw2NIEq5pGXVh8yIHCd1UiLA
This link will auto download the PDF, you're looking for chapter 6 Thermal Specifications. The first link I posted forwarded to this link, as some of the specifications of thermal control have not changed since the 2nd generation, and are used on new sockets as well, your 3rd generation 3770K is covered in this information.
For Intel to warranty a CPU for 3 years they are forced to build in protective features that can cover every ambient situation they'll be used in. However Intel never guaranteed you the CPU would be running at it's maximum output capability, only that it would functionally operate, unless you overheated it, and then it would just auto shutdown. If you operate the processor within the thermal design window, (so to speak), you get maximum processing capability. Pretty simple eh, the key is operating it within that window, to always be able to get the most from the CPU.
FYI: Water boils at 100c at sea level, does that in any way come into your mind as an acceptable temperature to run your CPU at.
Might test that tomorrow with 1 gskill in slot A1 and 1 EVGA in slot B1.
I would not do that.
You will be crippling your performance forcing the M/B to run the lowest possible settings for the mismatched modules.
I am attempting to help you, not hurt you.
Even though this is the water cooling section, many do not realize the hardware setup configuration they are running may be partly responsible for their higher temperatures. System memory is sometimes a big culprit in this, simply because you may have had modules left from an upgrade and still wanted to use them since you spent your money on them. In most all cases if you are not overclocking the processor then it really doesn't matter as you can original Model T your way eventually through any app. hopefully. But if you are after performance and higher overclocks expecting it all to work together, then you need to configure for that.
