- Jun 27, 2002
problems with A64 DTR chip at stock speed
Well i got a 32000 DTR notebook to go with my new MSi K8N Neo Platinum because I wanted a garunteed CG stepping. I heard that some motherboards wouldn't recognize these chips correctly but I also heard that most new boards would be ok with these. When i started the system up and booted into windows i noticed that the chip was only running at 800MHz. I checked the BIOS settings and noticed that the chips default multiplier was 4x. However I was able to up the multiplier to 10x with a little extra voltage. Right now I am running prime95 at 2Ghz (which i believe is stock speed for a 3200 clawhammer chip) at 1.7V. Now according to newegg these chips should run at 1.5V so the voltage is a little higher than it should be.
What do you guys think? is my chip safe at 1.7V? keep in mind that i still plan to up the fsb on this chip so i dont want the voltage to be any higher than it should be at stock speeds. Is there a new BIOS revision that might fix this problem?
Thanx.
Thanx.
