I think APU's are going to change the future of HTPCs/Media PCs. The thing I like about these new AMD APU's vs. Sandy Bridge is that they are one chip both GPU and CPU integrated, unlike Sandy Bridge where is two separate chips.
For the Sandy bridge the cpu is on the same chip as the cpu: http://www.techpowerup.com/reviews/Intel/Core_i5_2500K_GPU/
AMD = Same Chip GPU/CPU
Intel = 2 Separate Chips
No, Lynnfield had the cpu/gpu in the same package but on different dyes, sandy bridge has both the gpu and cpu on the same dye.
Just do a google search for Sandy Bridge architecture and you'll see.
The CPU and GPU is not on the same Die. Sandy Bridge is 2 separate dies.
1 – Intel Sandy Bridge Overview
Sandy Bridge is the new line of processors from Intel. It’s the second generation of Core i3/i5/i7 processors and is an evolution of the previous Nehalem architecture. Sandy Bridge integrates a multi-core CPU and a GPU on the same silicon die. The GPU part of Sandy Bridge comes in two flavors: Intel HD 2000 Graphics and Intel HD 3000 Graphics. Sandy Bridge Core i3/i5/i7 use a LGA 1155 sockect.
You are talking out of you ***. Check this: http://www.geeks3d.com/20110103/intel-sandy-bridge-processors-cpugpu-launched/
Now, the Clarkdale cpus (socket 1156) had both the cpu/gpu on the same package but different dies. See this: http://www.xbitlabs.com/articles/cpu/display/clarkdale-sneakpeek_2.html
If you see in the picture there are 4 cores and 1 graphic processor. And please don't curse, it's not polite.
BTW, maybe, next time you can make sure that what you are posting makes sense before posting it.
I know there are 4 cores and 1 gpu, but they are all on the same die. Do you know what you are talking about?
Look at this, this is amd fusion, with you logic amd's gpu is not on the same die as the cpu:
http://realworldtech.com/page.cfm?ArticleID=RWT062711124854
Whether one solution or the other is on the same die or not isn't really the point. The only thing that matters is the respective CPU and GPU performance of the package.
Sorry I just had to teach this kid some knowledge about APUs... I think bobcat is going to deliver better performance since the CPU and GPU are integrated within each other. Theoretically a 4.0GHz CPU is a 4.0GHz GPU...
I've often wondered how much more competitive. AMD would be if they ever caught up on process
AMD would probably still be where they are at. Even when Intel's Presshots were a lot worse off compared to AMD's Athlon 64, Intel still held onto I believe 75% of the market share. Intel controls a lot of the OEM computer manufacturers through various means. Intel doesn't want to kill AMD, but they definitely won't let them gain much ground.
Anyways, I thought Nvidia does know how to manufacture CPUs, just won't compete against Intel? Such as the Tegra 2 and I believe they also acquired a company that had the license to some of Intel's tech, which from my understanding is Intel paid Nvidia back.
