- Apr 20, 2009
I use a home audio receiver for my pc's 5.1 speaker setup. I use the only HDMI connection from my graphics card, but if I want to connect my Vive Vr headset I have to disconnect the receiver. This isn't a huge deal, but sometimes when reconnecting you have to reboot so that newly opened windows don't get sent to the recevier. Which the computer thinks is a screen.
I need one of three things to make my pc audio experience alot easier.
(the first two are impossible to find)
1.) A sound card that outputs to HDMI. They actually exsisted for alittle while, but are gone now...
2.) A analog 5.1 receiver from the 1990's. One that had a seperate RCA input for each channel. Afew specialty companies still make these, but they are $1000+.
3.) A HDMI audio only driver for my motherboard HDMI output.
To try and solve the problem of having to switch the HDMI connecting out randomly I am thinking about using the motherboard's HDMI output. If I plug in the receiver nothing happens, I think I have to install the mobo's VGA driver for the HDMI to be noticed. But that leads to my question, before istalling the VGA on-board graphics driver, is there any chance theres a driver for audio only from HDMI's?
I know I'm not losing a huge amount of performance, but I don't like my computer wasteing resources sending video to the receiver.
And I don't like losing my cursor on a display I can't see.
Also if video/websites are displayed on the receivers video signal, the receiver will randomly resize its output and this causes the audio to stop for afew seconds while the receiver switches resolutions. With some sites this would happen over and over again.
You'd think there would be a better solution for people who use receivers for their pc audio, but I guess its alot less common than I think.
I tried optical, but I don't think my receiver can receive compress audio, and since HDMI has better quality I'd prefer HDMI.
Anyone else using receiver audio?
Maybe someone has a better way to get the job done?
Or a magic mobo driver that fixes all my woes in one single click?
