- Aug 13, 2015
Greetings all.
I have a system with an E7500. I was getting temperatures in the 30s and 40s celcius when idle and it was hitting 80 under normal load and 100 under full load.
I reapplied thermal paste to try and resolve this problem. Arctic silver 5, using the line method. Temps were worse mid 40s when idle, 100 under normal load.
I reapplied again using pea dot method. Temps were even worse. Mid 50s when idle, and i dared not test load temps.
So some questions: What methods do I use for arctic silver 5 on an E7500? Does the paste have to cover the whole thermal surface of the CPU once it has squished? Can too much paste cause overheating?
