- Sep 29, 2012
- Fresno, CA
For a pending WC upgrade, I am planning on using two PWM D5 pumps, two 120mm PWM fans and two 140mm PWM fans (both sets will be NB fans), in conjunction with one four pin Mymytoys PWM distributor. However, I would like to confirm that they can be used in such a manner? Meaning, (1) when using such a distributor do all the attachments need to run on the same RPM or does that not matter and (2) is that too much to run on one distributor?
I was planning on using a y-splitter for to connect both pumps to the distributor, and y-splitters for each of the two sets of PWM fans, connecting the distributor to the MOBO. So there would be three connections, each with two items attached; with the pumps providing their own power, while the four fans would be drawing all of their power from the MOBO.
...Or is there a better way to do this? Also when connecting to the MOBO for PWM fans, are all those connections based upon a single monitoring point, or is each for a specific part of the MOBO (in other words, does it matter where a PWM device is plugged into for a set of fans to wind up and down according to say overall temperature of the MOBO, CPU, or whatever)?
