I really want to hit 1800 mhz with my 1900+ palomino, but I just can't seem to. I was thinking about volt modding my motherboard to get more voltage, but I'm not sure if my temps are too high for that.
idle temp: 34 C
max load temp: 45 C
running at 1.85 volts and 1768 mhz
That's with an SLK-800 and a 48.5 cfm variable speed YS-Tech fan. (also, are those temps reasonable with this HSF combo?)
What kind of temps would I need to hit 1800 mhz. (keep in mind that it can run at that speed, but gets errors in Prime95 after a couple hours.
And finally: Are those temps too high to think about setting my voltage higher than 1.85?
idle temp: 34 C
max load temp: 45 C
