- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
I have a Q6600 processor and I OC'd it to 3.0GHz and I was wondering if these temperatures are fine, otherwise I'll just set the clock speed back to stock settings.
Specs
CPU - Intel Q6600 @ 3.0GHz
RAM - 8GB (2x 4GB) DDR3 @ 1333MHz G.Skill Ripjaw
Motherboard - Gigabyte P45T-ES3G
GPU - EVGA NVIDIA GeForce GTS 450 1GB
Storage - Seagate 750GB HDD, WD 160GB HDD
PSU - LSP650 Pro (650W)
Idle Temperatures
CPU - 48C
Motherboard - 34C
GPU - 48C
750GB HDD - 30C
160GB HDD - 27C
While Gaming
CPU - 60-64C
Motherboard - Around 40C
GPU - 67-72C
Oh and my heatsink for the CPU is the Rosewill RCX-Z2. I have 3 fans bringing in air, a 120mm in the front, a 120mm on the bottom, and a 250mm on the side, and I have 3 fans exhausting air, 2x 120mm fans on the roof and one 120mm in the rear. PSU is bottom mounted and has independent cooling. I just have a feeling my system is a little warm for all these fans. In case you're wondering, the case is the AZZA Toledo 301: http://www.newegg.com/Product/Product.aspx?Item=N82E16811517013&Tpk=azza toledo 301
Any feedback on this is appreciated, too hot, just fine, could be cooler?
Specs
Idle Temperatures
CPU - 48C
Motherboard - 34C
GPU - 48C
750GB HDD - 30C
160GB HDD - 27C
While Gaming
CPU - 60-64C
GPU - 67-72C
