GojiraCometh
- Mar 16, 2016
CPU: Intel i7-4970k
CPU Block: EKWb Supreme MX
Radiators: 1x360mm(aquacool) and 1x240mm(xspc)
Pump: Variable D5 / Photon 170mm Reservoir Combo. Set to Highest Power (5/5)
Fans: Lots of them, Corsair SP's, Cougar's, etc.
GPUs: 2 x gtx 980 reference
GPU Block: EKWB Nickel
(NYC Metro Area) Temps Right now: 73 degrees in apartment, 53 degrees outside
CPU and GPU are currently: stock ; defaults ;
Temps During Various Tests:
1 - Folding @ Home:
2 - Intel XTU CPU Stress Test:
3 - Prime 95 v28.7,build1 (I believe this version was problematic for my cpu)
I have a few questions:
1 - Is my loop set up correctly for the gear I have?
2 - Are my temps normal? (minus the prime95 temps bc I believe there is a well known issue with high temps on Haswell chips for certain Prime95 versions)
3 - Is it normal to see 80 degrees on a warmer/nicer day under full load?
4 - What can I improve/change for better temps/efficiency/power.
Thanks in advance for your input.
- - - Updated - - -
Idle temps are btw 28 and 32 on cpu/gpus
Here is the overall flow:
1 - Folding @ Home:
- - - Updated - - -
