- Nov 7, 2004
I have been giving the task of fixing a AMD rig for an old school friend and backing up her photos and what not. I got the tower home and booted it up after 2mins into the system and on XP Home's desktop I was greated with the malware Personal Antivirus saying the system had a trojan horse.
ASrock ALIVE NF6P-VSTA AM2+ Bios 1.50
AMD 1650LE 2.60ghz (I think) CPU but upgraded to a AMD X2 4400+
Elixar 1GB DDR2 memory
Maxtor 160GB SATA-II HDD (disc check reported bad blocks not much but some)
Onboard 6100SE graphics and Realtek Onboard HD Audio
Anyways I just backed up the photos to a pen drive, now before I formatted the system I used spybot to remove that annoying malware I removed Norton 360 because it's bloatware and some other crap stuff I put spybot, AVG Anti Virus F.E, ZoneAlarm and Spyware Blaster.
I gave the system scans removed the spyware malware etc no virus' they also wanted me to upgrade the CPU and so I needed to flash the BIOS to the latest version. That was a success and so I rebooted to do a fresh install of XP but I got them to part with some cash for Pro SP3 because I believe the Home Edition SP2 was a cracked copy. Right the fresh install went with no glitches I installed DirectX 9.0c (Mar 09) and powered down as I had to go to work.
I just tried to power it up and it wont the motherboard has a Nforce 430 chipset and it's using the onboard 6100SE graphics but nothing will work. The DVD-RW drive's light keeps flashing twice and so does the HDD light I have cleared CMOS and I got it to power-up once and as I was setting the BIOS clock and it gave me a corrupted screen and went blank.
Could the board be dead the BIOS update was a success the new CPU installed and I set up with load default settings I just can't work out whats wrong??????
