correct.According to Asrock website Z370 Pro4 does not have any USB 3.1 gen2 connectors, is this true? According to the manual it has a USB-C type connector, but the speed is supposedly USB 3.1 Gen1, not gen2.
I've put on the 1.30 bios without problem. I can't say it made any difference to manual overclocking or other performance.
Unfortunately this mobo doesn't allow you to set a fixed voltage, so you have to monitor and adjust with the relative voltage control. Asrock's own monitoring software is the one that gives the most believable CPU voltage reading, but I haven't checked recently if other software has been updated similarly. I overclock in Windows using Intel XTU software, and from there I can adjust both multipliers and offset voltage. My 8350k does 5.0 GHz (for non-AVX workloads) at +275mV offset, which is read by the Asrock software as around 1.4v. The reference that the offset works from may vary depending on CPU so don't take my number by itself.
Ram: I'm only learning overclocking that myself. What's the exact model/timing of the kit? I had some difficultly getting my kit running at 3600. I had to reduce VCCSA and VCCIO from what the modo sets by itself to get it working. I can't remember the values, but I think it was 1.05v for IO, and 1.15v for SA.
I'm running mine open bench. The only fans on mine are the CPU ones and they seem to spin up and down on demand.
Also can't say I've seen any OC failing to stick when doing settings in bios. Only thing to note is if it fails to boot repeatedly it will go back to stock settings. There's a message on boot screen for a few seconds before it continues booting, so if you miss that you don't know it did it.
