Yup, biggest difference is that the Extreme6 uses higher quality MOSFETs in the VRM section of the board. Basically that it'll supply cleaner power to the CPU.
i have E6. like it so far, only thing thats off is that if youre doing any kind of OCing the vcore is off. you need a DMM to check the exact voltage going into the board. Regardless thats with both E6 and E4. So i guess i didnt help your choice
