- Jan 9, 2012
- Massachusetts
- Thread Starter
- #21
I just took mine up to 2.40, Gonna go in and take a peek and reset my OC settings
Ok, I finally got around to it, reset my voltages to stock and bumped my multiplier back up to 45 on stock voltage and just ran 20 min of prime and got bored. Im happy, I could not do that before with stock voltage so perhaps this 2.30 bios has made things even better ?
Im gonna run it this way and see what happens. My temps in prime never got above 82 on any core with 100% load so all seems good.
Try some Diablo III tonight and maybe some Darkness II and see how she runs.
How are you setting "stock" voltage? Did you note what CPU-Z was reporting for your vcore under load b/n the 2 BIOS'?
Also lowering PLL can bring down your temps w/ no ill effects. I'm at 1.627v now. 1.71v is typically a given and I've seen some guys go down to 1.5v.
Nice vcore! I bet you can get those temps down if you tweak some more. I ninja edited my post above with some tips if you're interested.
Ha ha! I've been posting in that thread a lot too!
My P95 methodology is very similar to that guide, but I think I've got a few more details to make the quest more fruitful.
Can any other ASRock z77 Extreme4 owner confirm the following BIOS behavior as normal.
BIOS version 2.40
After entering the BIOS/UEFI and making a change (anything) then performing "Save and Exit".
I am expecting the BIOS changes to be saved and the system to exit and restart.
Mine does not restart, it saves the changes, exits the BIOS, and then shuts off. (I need to hit the Chassis power, or the on-board power button to restart. This seems very alien to me compared to the non UEFI BIOS I am familiar with.
Just trying to figure out if I am insane or the board...
CB
BIOS version 2.40
CB
Today 12/4 ASrock has put up the newest Bios for the Z77 Extreme 4 motherboard. Version 2.70, here are the updates.....................I wonder why they skipped 2.60 ? LOL
Version 2.70
1. Support UEFI PXE boot.
2. Modify VT-d Capability will be unsupported after flashing BIOS P2.50.
http://www.asrock.com/mb/Intel/Z77 Extreme4/?cat=Download&os=BIOS
Edit :: First guinea pig here, Im at 2.70 and all is well (so far)
