This is not really related to some mosfet brand. This is mostly a temperature issue when you have a WCed cpu. You end up with zero airflow for the memory and VRM's. Usually, the memory is OK if you dont push it really higher than spec, but the VRM's heat up quickly when OCing and at those clock ... you NEED VRM's cooling. NM the motherboard you have ... Even a 400+$ asus rampage V extreme will need VRM cooling at these clock.
