- Jul 22, 2004
- Port Elgin, Canada
Can anyone point me in a direction on how to work with the RAM? I got my computer semi stable at 2475mhz (275HTT and 1.55v), it is stable in windows (so far) but Prime95 isnt too happy ATM.
Super Nade said:Mate,
The ramguy is right. I'll change it in the database. Sadly, TCCD isn't fully exploited by this board. People have reported some measure of success with various TCCD. I, personally have hit 250MHz, 2.5-4-3-10-1T. Not the best result for expensive RAM.
How long did you burn it in? Something is seriously wrong here. Can you try an older BIOS and see what happens? Or else, try a newer beta BIOS and see what happens?
Super Nade said:250 MHz FSB? That is strange
I had it upto 275MHz on a Newcastle! The first thing that comes to mind is the BIOS. ASUS are not known for their stellar BIOS support (unlike DFI), so one would be forced to wait. Sadly, modded BIOSes are few and far between, so tough break on that account.
Just as a pointer, I hit 260MHz 2.5-3-3-10-1T stable with my XBLK's.
I clearly remember the disaster with the Winchesters. Everybody had this great Winchester but were plagued by system instabilities. As always, a crappy 1007-1009 BIOS was the culprit
jeeplover said:I would like to point out I can enter into windows under 275MHz with memory 1:1 2.5-3-3-6, but can not pass superpi and prime95 test.
Super Nade, Are you able to run 275MHz stably?
Super Nade said:Absolutely yes! I no longer own the board nor the CPU so I can't duplicate those results. However, I'll try to dig up some old screenshots for your viewing pleasure .
I think your problem is with the 2.5-3-3-6. Did you try 2.5-3-3-10 or 2.5-3-4-10 ?
*Note*
I said my HTT scaled upto 275MHz infact 279MHz but I ran under a divider diffrent from 1:1!
jeeplover said:I set memory 3-4-4-10 and can not stablize the system under 260MHz. I think it is not the issue of memory but CPU or motherboard.
Since you can stably run under 275MHz, why do you switch to DFI? Just curious.
What your old cpu stock frequency? 1.8G or 2G?
Super Nade said:I don't thisnk this board likes CAS 3. I could not even boot into Windows with CAS 3 (both Patriot XBLK and Corsair Value RAM).
Why did I switch to DFI ?
The A8V is an excellent board with a decent feature set. However, I wanted more control and the high VDimm on the DFI board was very attractive for my BH-5, which was wasting away. My only gripe with the A8V was the limited DRAM Voltage and the fact that it didn't run my TCCD to its fullest potential. 279Mhz was the absolute wall I hit. One could blame my 130nm Newcastle for it, but I believe people with Winchesters had similar problems.
Nothing wrong with the board, I just wanted a bit more features in terms of overclockability. Also, at that time modding a less fancy DFI Ultra-D to SLI seemed attactive. Since then I've sold my 6600GT and I'll be running an X800XL .
Let me emphasize that there was nothing wrong with either the board or the 6600GT, however, something could be seriously wrong with me
jeeplover said:Hehe, interesting.
I am also considering switch to DFI nf3 Ultra-d after more and more people confirm the Rev 2 is much better than Rev 1.
Super Nade, you have not answered my question: Do you have to low cpu multiplier to reach 279MHz FSB? I am still thinking the 250MHz limitation due to CPU because I can stably run 270*8.5=2.3G on that board but can not do 255*9=2.3G. Really weird.
I have the same CPU and motherboard. I have heard of a lot of problems with the BIOS versions from 1.10 onward. (There have been issues with the 5:3 and 3:2 dividers.)AdmSovereign said:Sorry to barge into this thread, but I've been having no luck OCing my NewCastle 3400 (yes there are S939 3400s). I've tried lowering the HTT and raising voltage. RAM is not an issue unless the A8V divider is failing or something.
Specs
AMD64 3400+ 939
A8V Deluxe rev 1.xx w/latest BIOS as of this post
1024MB Mushkin Green Line (basic, 2.5-3-3-7 or 8 can't remember)
120GB HDD
Onboard sound only
GeForce 6800NU
Ultra X-Connect 400w
Two front case fans - intake
One back fan - outtake (is this a word?)
Custom cooler on graphics card
Stock cooler on processor
OK, FSB/HTT is at 240MHz, divider on memory is 3/2. Keeps memory at DDR400. CPUZ confirms this. Proc is 2.4GHz (2.2GHz stock). Volts are stock. Increasing volts doesn't do anything AFAIK because AsusProbe reports that the processor is getting 1.502v when I set volts to be 1.525 - 1.575. So the processor just gets REALLY hot (65C+). I'm getting random restarts, and failures in Prime95. Memtest hasn't been run because the memory is held at stock. (DDR400)
Oops. That's what I meant.AdmSovereign said:That would be version 1009 right?
Here's my RAM and here's my Heatsink fan.AdmSovereign said:What kind of RAM are you running? Also, what cooling are you using?
