- Jan 9, 2005
- Livonia, MI
AdmSovereign: You mentioned in a previous post that your CPU temps get up to 65C? If that's true, I'm willing to bet that temperature is what's causing your system instability. That's WAY to hot for an A64 CPU. My CPU at full load doesn't go much over 40C.
Regarding memory dividers, BIOS versions 1011-1014 all have screwed up BIOS settings. Setting the divider to 3:2 in BIOS actually activates a [5:3 DDR333] divider, and the [5:3 DDR33] setting activates a [2:1 DDR400] divider. This is consistent with what you have reported. I have spent quite a bit of time researching this issue, and this has been the case for every single person using BIOS versions 1011-1014 (those who have reported memory divider issues). I suggest that you stick with BIOS 1009 since you will have all memory dividers available to you. With FSB at 240, a working [5:3 DDR333] divider setting should yield a memory speed of 200 MHz (DDR400). Using [3:2] should yield a memory speed of 173 MHz, so nothing is wrong with your dividers a long as you stick with BIOS 1009.
That being said, you need to determine the source of your instability. Please clarify for us your temperature issue first. That seems most likely to me.
