RAM: 2x 2gb DDR3 PC-2000mhz CL7
Mother: Asus M4a78t-e
CPU: AMD 1055t (arriving in 1 weak+)
CPU2: test on AMD 945
All tested with CPU2 AMD 945. 1055t coming soon, but not yet.
Iam Over Clocking my mother Bus to 250-285mhz in order to OC CPU and also get the RAM frequency to 2000mhz. But only could get Ram running at 1700mhz, more wont boot.
But i read in this:
"However, you have to make sure that the frequency of the North Bridge built into the processor and the frequency of the HyperTransport bus don’t exceed 2.0 GHz that is why you have to lower corresponding multipliers accordingly. The same is true for the DDR3 memory frequency: the actual resulting memory clock shouldn’t exceed what the modules are physically capable of, so you may have to lower the corresponding multiplier as well."
So does it means that i just CANT get my ram running at 2000mhz on this motherboard? :/
Thanks for your time
But i read in this:
