Hello, I'm trying to run an Asus P2B mobo with HW rev 1.02 and a FC-PGA CU-celeron 700, using a MS6905 MASTER (ver.2) Slocket.
I updated the BIOS to the latest version.
Okay, the mobo boots with a Celeron 300 Slot1,
with a FCGA Celeron 366, using the slocket, but with the FC-PGA proc, it remains dead.
According to the Asus site, you need HW rev 1.12 or higher, but I like to know what the exact problem is..
My mobo seems to support a multiplier of 8 at most
and I need 66 x 10.5.
Can someone tell me, what I need to modify to the slocket or proc, to run 100 x 7? And are there other things that might need to be modified on the mobo, such as the Voltage regulator?
Cheers,
manuel
Cheers,
manuel
